ArcGIS Pro 3.6 and FME Form 2025.1 and FME Flow 2025.1 Compatibility
  • Feb 19, 2026 4:59 PM UTC
  • 147 views
mgaylord
Hello!
I am trying to make sure that we have compatibility across all our different platforms. Our organization has recently upgraded to ArcGIS Pro 3.6. I was taking a look at the compatibility matrix and noticed that for ArcGIS Pro 3.6 is says the minimum FME version to have is 2025.2. Does this mean that FME Form and Flow 2025.1 cannot be used with ArcGIS Pro 3.6?
Any help is greatly appreciated!
j.botterill
Forum|alt.badge.img+69
  • Feb 20, 2026 7:36 AM UTC
Correct. If you are using ArcPRO 3.6 then the minimum FME form and flow version is indeed 2025.2
If FME and Esri are not compatible, your GIS integration stack is not stable — even if individual jobs “seem to work.”
hkingsbury
Forum|alt.badge.img+73
  • Feb 22, 2026 7:59 PM UTC
The versions in that table/article are versions Safe has tested, and confirm that they work (and will support issues with)
It might work with versions outside those ranges, but it is not tested, supported, or guaranteed. Therefore,as James rightly put, this would mean your stack is not stable
