ArcGIS Online (attachment photos) to GDB
henriquereisgeo
Hello all,
I am trying to use “reader” AGO data to provide a “Writer” GDB which contain the attachment photos
I have been advised to use this process:
In the “reader” I set up o include attachment:
and selected the attributes:
Set up “AttributExposer”
In “RasterReplacer” I am not usre what should be done:
When I try to select “Data:
Became unable to process:
I have been advised
“ It seems you missed the last step in my first response.
   "The arcgisonline_attachment{}.data attribute holds the raster data which you could then use the RasterReplacer to recreate the image."
You should add RasterReplacer to restore data into an image and then use a writer with the correct format (which you selected within RasterReplacer) to write those output.”
Does someone one know what to do?
Thanks
Cheers
paalpedersen
Forum|alt.badge.img+7
You ned to use the listExploder on the arcgionline_attachemnt list
then you can use the data attribute.
henriquereisgeo
Hi
Thanks
I could manage it, but would u know which number I should select in “Select list element numbers).
Would be which field is saved the photos?
All the plan
AliAtSafe
Forum|alt.badge.img+23
  • June 6, 2024
henriquereisgeo wrote:
Hi
Thanks
All the plan
Hi, @henriquereisgeo.
Thanks for posting. I tested your scenario and can confirm selecting 0 as the list element will recreate each attachment image. I wrote it out using a JPEG Writer and have seen the images exported. I hope this helps! If not, don’t hesitate to reach out!
