All attempts to create a web service authentication fail on redirect
  • Sep 22, 2024 8:11 PM UTC
  • 74 views
jsdbroughton
Forum|alt.badge.img+4
I have followed the documentation on setting a custom OAuth2.0 web service connection and all steps work within the Test… flow until it comes to redirecting to https://localhost . Is FME listening to a specific port on the localhost or should it be registering itself as a temporary server?
This is the returned screen.
Following the same flow within a external browser window also ends up here but the returned access_code is present in the URL.
How is this being retrieved by FME - I’m kinda stuck here.
todd_davis
Forum|alt.badge.img+23
  • Sep 25, 2024 4:46 AM UTC
I think we need more information here.
Are you doing this in FME Flow? Assuming, Yes
What is your redirect uri that you are pointing to?
Is your domain name https://localhost (and you have created a cert for localhost?)
If all the above are yes, then your redirect URI would be https://localhost/fmeoauth
Easy way to confirm, goto that link and you would get:
