Adding BIM360 Connector with non FME Python Interpreter gives error
  • Nov 9, 2021 10:34 AM UTC
  • 42 views
jkr_wrk
Forum|alt.badge.img+37
For others to know:
FME 2021.1
When the default interpreter is set to the Python in the Arcgis Pro folder adding the BIM360 Transformer results in a failing BIM360 Transformer. We can solve this by removing the Autodesk BIM360 Docs Package, selecting the FME Python 3.7+ Interpreter and re-installing the BIM360 Transformer.
andreaatsafe
Forum|alt.badge.img+17
Hi @jkr_da​ ,
 Update: The issue is now resolved. With FME 2022.0 and newer, when installing packages the custom Python interpreter is not used.
Thanks for reporting this issue. I was able to reproduce this issue only when setting the Python Interpreter (via FME Options > Translation) to a custom python interpreter.
eg:
Custom_Preferred_Python_Interpreter
I've filed an issue (internal tracking number: FMEENGINE-71252) for this so that it should not be an issue with installing FME packages when setting a custom interpreter.
Thanks,
Andrea
