A huge bug in 2019.2?
  • Dec 11, 2019 2:28 PM UTC
  • 86 views
aguan
Forum|alt.badge.img+11
Just downloaded 2019.2, and quickly run into a big issue - the HTTPCaller query parameter does not save. For example, if I set a pagesize parameter and its value to be 1000, click OK, reopen it, the value is empty. If I open a similar workbench previously saved in 2018.1, which has pagesize = 1000, change it to be 10000, click ok, reopen it, it is still 1000. I am on windows 10.
Best answer by mark2atsafe
I've looked in a few places (Whats New, Developer Database, Support Database, etc) and I'm not seeing any reference to this, either it being an issue in 2019.2 or being fixed in 2019.2.1. I also tried it (2019.2.1 on Win 7, plus 2019.2.0 on Win 2016) and it seems to be fine for me.
At this point the only thing I can say is please do let us know how it works with 2019.2.1. If it's still a problem I suggest you file a case with our support team (safe.com/support).
Oh, one question would be, is this an older workspace opened in 2019.2 or are you placing a new transformer? If it's an old workspace/transformer perhaps upgrading it will help (if there is an upgrade option).
  • Dec 11, 2019 3:38 PM UTC
HI @ag, I wasn't able to reproduce the symptom you described, with the latest FME 2019.2.1 build 19813. If you have FME 2019.2.0 installation, try upgrading it to 2019.2.1.
aguan
  • Dec 11, 2019 5:26 PM UTC
@takashi, mine is 2019.2.0.0, downloaded just last week. did not know 2019.2.1 is out already. Will try shortly.
mark2atsafe
Forum|alt.badge.img+59
  • Dec 11, 2019 5:58 PM UTC
aguan
  • Dec 11, 2019 8:44 PM UTC
I installed 2019.2.1 and don't have this issue any more. @mark2atsafe, @takashi. Thanks.
