502 response FME Flow webhook
  • September 25, 2023
  • 120 views
stefan.vdberg
Hi FME community,
I am trying to start a job on FME Flow from another application by making use of a webhook and a token. The trigger results in succesfully starting a job on FME Flow, but the response is most of the time the following:
502 - Web server received an invalid response while acting as a gateway or proxy server.
It looks like this only happens when the job takes longer than 2 minutes. Does anyone have an idea where the 502 response comes from? This indicates an error while in fact the job is started as expected.
Version 2022.2
Build 22765 - win64
Best answer by hkingsbury
stefan.vdberg wrote:
Thanks for your response @hkingsbury​. You are correct, we are using a reverse proxy (IIS) and it indeed looks like a timeout there, because the call waits for the job to succeed or fail. I will try to split the call into submitting the job and retrieving the result.
as you're using IIS i'm therefore assuming you're using ARR - it could be as simple as increasing the timeout in ARR.
But yes, for longer running jobs, it generally is a good Idea to follow a more async style process and submit a request (and retrieve the job id) then poll the job ID until you no longer get a processing state
hkingsbury
Forum|alt.badge.img+55
My first thought is that you're reaching a connection timeout somewhere along the line.
Are you connecting to Flow through a reverse proxy or similar?
stefan.vdberg
hkingsbury
  • September 26, 2023
stefan.vdberg
Agree. Thanks for your help :)
