Archived
Workspaces Failure E-mail Notification
Related products:FME Flow
  • Dec 28, 2016 12:00 AM UTC
  • 80 views
Hello FME Community:
My suggestion is to provide the ability to send one e-mail notification listing all failed workspaces on daily bases. This will help admin to pick up what failed with a quick glance at a single e-mail message.
Example: jobs A,B,C,D, and E are scheduled to run daily
If jobs A,C, and E fail --> send a single e-mail stating that jobs A, C, and E failed.
  • Jan 3, 2017 9:50 AM UTC
This is relatively simple to implement using a scheduled workspace and querying the REST API with an HTTPCaller, e.g.
/fmerest/v2/transformations/jobs/completed?accept=json&detail=high&limit=-1&offset=-1
Then filter out those jobs where "status" = FME_FAILURE etc.
Documentation: https://docs.safe.com/fme/html/FME_REST/v2/apidoc/index.html#
rylanatsafe
Forum|alt.badge.img+14
I think this is an excellent suggestion by @david_r. It is likely possible to achieve this by configuring a workspace and have itself scheduled to run daily – make sure you set to notify if this fails! Would this address your concerns / idea, @mnabhani?
*Please also note that there now is Version 3 of the FME Server REST API. I would recommend using the endpoint documented here: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/transformations/list_get_19
As an added bonus, you could write out the 'offset' to a lightweight database (e.g. SpatiaLite) to reduce the number of completed job records you read in – i.e. if that starts to incur significant overhead for a busy FME Server!
