Archived
Workspace Reader improvements
Related products:FME Form
  • September 11, 2018
  • 29 views
lifalin2016
Forum|alt.badge.img+41
Hi.
I'm trying to utilize the Workspace Reader to handle my almost 200+ repository of workspaces.
I stumbled over a few issues with the Workspace Reader, that I want to propose as improvements.
  • "PublishedParameters" include both published and private parameters + parameters to embedded custom transformers. But it doesn't include any way of distinguishing between them. Please add an extra attribute for this.
  • "WriterParameters" does not include e.g. the MSSQL_SPATIAL parameters for executing statements before and after translation. Are they available elsewhere ? If not, please add.
This is what I've found sofar.
Cheers
nic_ran
Forum|alt.badge.img+20
  • April 24, 2020
I'd like to add to this request:
- published parameters currently make the parameter name, type and default value available, it would be helpful to also have the "prompt" as that's what the user sees.
nic_ran
  • April 24, 2020
I've discovered that this information is buried in the published_parameter_type attribute, although this is not clear in the documentation. A documentation update would be great.
It would also be great if this could be returned in separate attributes by the FME Workspace Reader as it's a pain to parse in the workspace.
From my interpretation of the data returned by the reader, the published_parameter_type attribute format looks like:
- GUI [IGNORE] [OPTIONAL] <paramType> <name> [choices] <prompt>
Where:
- [IGNORE] is optional and, if exists, signifies a private param
- [OPTIONAL] is optional and, if exists, signifies an optional param
- [choices] is optional and exists only if the paramType is a "choice" type parameter
I built a custom transformer to help parse out this information until Safe (hopefully) supports this more directly with the Workspace reader:
https://hub.safe.com/publishers/front-point-consulting/transformers/parse-published_parameter_type
