Archived
Workspace BoundingBox rulling them all Inputs/Readers
Related products:FME Form
  • December 19, 2017
  • 43 views
juanmahere
Forum|alt.badge.img+15
Using the Bounding Box published parameter allows you to test small areas your big workspaces/workflows, so I could say that is THE ONE FME capability that makes my work much more efficient ;) ... Unfortunately, I think there is a little more to be improved:
I use to face this hard job of creating the corresponding User Parameter within the Search Envelope options to create a BoundingBox whereas the Workspace need to be run spatially, for one of the inputs that is included in the Workspace, and then, LINK the rest of Inputs/Readers to those four X-Y parameters.
Even when you change/delete that associated bounding box Input, you need to recreate the Published Parameters and link again the rest of your inputs. Imagine a Workpsace with 6-10 readers...
I was wondering if there is a possibility to establish within a Workspace an independent bounding box parameter which encapsulates/rules spatially the rest of Readers/Inputs inside, like a global Bounding Box or something like that.
Thanks,
LizAtSafe
Forum|alt.badge.img+25
Updated idea statusGathering Interest→Archived
Idea merged into:
All the votes from this idea have been transferred.
