Released
Versioning of Readers and Writers
Related products:FME Form
  • Oct 29, 2015 12:00 AM UTC
  • 10 replies
  • 108 views
fmelizard
Forum|alt.badge.img+22
Versioning on the Readers and Writers - similar to Version on the Transformers. To know when to delete and add a new reader. Or notify when a reader/writer from an older workspace needs to be deleted because of changes in the format.
mathieu_ambrosy
Forum|alt.badge.img+5
+1000 The ability to update Transformers in FME 2016 is awesome. Same thing for readers & writers would be fantastic.
For now we can just know wich version of FME has been used to add a reader or a writer (GENERATE_FME_BUILD_NUM). A true version number like for Transformers and "upgreadable readers and writers" in Workbench navigator would be great.
davideagle
Forum|alt.badge.img+21
  • Dec 14, 2015 12:24 PM UTC
...in particular the ability to identify which parameters are new or have changed, in the same way as the new transformer upgrade approach has been implemented.
A project I worked on recently involved a workspace with very old Geodatabase readers and writers, man were the new versions different when it came to available parameters. This is issue is just not obvious enough...
hansh
  • Jun 2, 2016 10:39 AM UTC
This would be really helpful! I just had an issue that I reported where the answer was just this: upgrade the writer.
dbaldacchino1
Forum|alt.badge.img+14
Was just running across this issue. If there is a change/improvement in behavior and you don't necessarily know about it, when loading older workspaces into newer versions, it is imperative to know when to rebuild some parts to get the updated functionality.
fmelizard
  • Jan 10, 2017 1:24 PM UTC
Safe Software PR#31773
jdh
Forum|alt.badge.img+41
  • Feb 8, 2017 5:45 PM UTC
This would be very useful with the performance enhancements to certain readers in 2017. ex csv, where the only way to take advantage of it is to replace the reader.
fmelizard
  • Feb 9, 2017 7:05 AM UTC
Yes, we agree. It is very high on our list.
fmelizard
  • Mar 31, 2017 4:15 AM UTC
Well, a *form* of this is in the FME 2017.1 beta. That said, it is still not quite where we want to be -- for example, if we retire a format like CSV and replace it with CSV2....we don't do the "upgrade" to CSV2 (yet). And we also aren't tracking or notifying if there are things that have changed. Give us some time though -- we're planning to hit this for FME2018....
fmelizard
  • Apr 14, 2017 7:46 PM UTC
The team advises that in FME 2017.1, if you "update" CSV or SHAPE readers, you'll get turned into their rewritten NEW versions and enjoy all the new privileges therein contained.
davideagle
  • Jun 27, 2017 9:43 AM UTC
@daleatsafe thanks for yours and the teams work on this so far. To be honest I'd settle for exposure of issue at this stage by allowing the reader\\writer version to be turned on and shown, like you can do for transformers. That way someone at least knows that if they compare two readers side by side, they can easily see one is of a higher version than the other and it might be worth considering an upgrade. Actually doing an upgrade is no great shakes if you know it's a possibility. Likewise, when transformer versionning was introduced we only ever knew the current version, not that there was a more recent version available. That was a handy starting point and would be great for readers\\writers to begin with. I do however realise that this is complicated by FeatureReaders and FeatureWriters... Thanks, Dave
