Archived
Using binding of named parameters in SqlExecutor/SqlCreator
Related products:Transformers
danilo_fme
  • danilo_fme
    danilo_fme
nordpil
Just for clarification - this is not about fme workspace parameters, rather about SQL named parameters.
Named parameters provides better security against SQL injection, improved query plan caching, ensures proper type handling among other things. Another advantage is that it makes it easier to just copy/paste the sql-code from a sql editor (like ADS, Dbeaver etc) where one would be provided with prompts to fill in the parameters.
It would be amazing if one just name a sql paramter the same as an attribute in the feature, and it would be picked up that way… !
PierreAtSafe
NewOpen
PierreAtSafe
Idea merged into:
https://community.safe.com/ideas/sqlexecutor-support-for-bind-variables-30922
All the votes from this idea have been transferred.
andreaatsafe
Forum|alt.badge.img+12
OpenArchived
