Archived
Use IAM Role in S3 Bucket Action in Automation
Related products:FME Flow
jelle
Forum|alt.badge.img+23
Use the IAM Role when authenticating in an Automation action, writing to an S3 bucket. When building the automation, it is required to specify a AWS Access Key ID and a AWS Secret Access Key.
This should work in the same way that IAM Roles are supported in the S3Connector. That requires that FME is running on an EC2 instance with an IAM role configured on it.
jbradfor
Forum|alt.badge.img+7
  • August 18, 2022
Yes, our security department is frustrated with the only option to connect to AWS is via Web Connections AK/SAK.
LizAtSafe
Forum|alt.badge.img+25
Open→Archived
