Open
Use attribute value in RandomPointGenerator
Related products:FME Form
  • Jan 11, 2024 8:10 AM UTC
  • 74 views
jonas_nelson
Forum|alt.badge.img+34
There is a custom transformer named RandomPointGenerator which can generate random points in polygons. However, it can only use the same single integer value for all polygons. If the possibility would exist to create N number of random points, where N is an attribute value different for each polygon, this transformer would be much improved.
jochgem
  • Mar 29, 2024 1:26 PM UTC
I totally agree. Moreover, if you could specifiy what needs to be randomized, such as an integer, location, string value, etc. it would create even more benefits for the community.
jochgem
  • Mar 29, 2024 1:29 PM UTC
Hi Jonas,
See the post below that is in part answering your problem:
