Open
Unleashing the power of variables!
Related products:Transformers
  • Dec 16, 2019 12:00 AM UTC
  • 8 replies
  • 258 views
bo
Forum|alt.badge.img+10
A parameter is like an argument that is static. A variable, however, represents a state and can be dynamically created and assigned in a workspace. I wish FME workspace UI exposes variables the same way it exposes parameters or attributes. Converting variables to attributes via VariableRetriever does not help, as attributes are about content while variables are about states and flow control.
I am in agreement with @bambography in his or her post.
https://knowledge.safe.com/questions/34563/can-global-variables-be-accessed-as-values-in-tran.html
  • Dec 16, 2019 8:25 AM UTC
I agree, there needs to be better support for using variables without using dedicated transformers (VariableSetter / VariableRetriever). My preference would be to add the following:
Function call, e.g.
@Variable(_my_variable)
Python API, e.g.
value = fmeobjects.FMESession().getVariable('_my_variable') fmeobjects.FMESession().setVariable('_my_variable', 'My Value')
jdh
Forum|alt.badge.img+41
  • Dec 16, 2019 10:46 PM UTC
At the very least the VariableRetriever should be a dropdown list of all the variable names used in a variableSetter.
itsmatt
Forum|alt.badge.img+48
  • Jul 30, 2021 2:56 PM UTC
Oh yes this would make things a lot easier. I would love to use a tester based on the value of a variable in the same way. Having to retrieve the variable as an attribute and then test is a real pain.
Also not being able to retrieve multiple variables with one VariableRetriever is another pet peeve (https://community.safe.com/s/idea/0874Q000000TlDuQAK/detail) also https://community.safe.com/s/idea/0874Q000000TkzIQAS/detail
Also what David said!
LizAtSafe
Forum|alt.badge.img+26
  • Oct 29, 2024 9:41 PM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • Apr 5, 2025 4:22 AM UTC
LizAtSafe
  • Jun 9, 2026 10:33 PM UTC
Open→Gathering Interest
LizAtSafe
  • Jul 23, 2026 7:11 PM UTC
Gathering Interest→Open
phoeffler
Forum|alt.badge.img+13
  • Aug 31, 2026 9:35 PM UTC
This would be very useful for situations where one is trying to pass information through to certain transformers or writers, such as portions of a compound file name, and doing so is either impossible or creates extra mess and problems when using User Parameters or Attributes.
Talking with a couple of staff members at Safe Software, they were in favor of greater access to variables as well, but unaware of the existing Ideas.
If not already merged in here, it seems that the Archived Idea at List of created variables (through VariableSetter) as attribute input in Variabl | Community supports one of the comments above, which is also a great Idea. Hard to see why the VariableRetriever couldn’t populate a list of available Variable Name options that have been created by one or more VariableSetters. This would be simpler and less prone to error.
Also agree with others that it would be more convenient to be able to set or retrieve more than a single variable per transformer. A grid layout for parameters and settings would make these transformers more useful and could reasonably support setting and retrieving one or more variables at a time. Reference: Improve VariableSetter/Retriever to allow to set/retrieve Multiple Variables | Community
