Open
Tunnels: allow 1..N and n..N connections
Related products:FME Form
sweco-senari
Edit: Got the header of the post wrong but i cant change it. Should of course be
Tunnels: allow 1..N and N..1 connections
Allow more efficient and cleaner workspace design with one-to-many connections for tunnels. Ideally if there is a 1..N or N..1 connection between transformers, one should be able to select all connections → right click → convert all connections to tunnels.
The expected layout would be according to picture below. The N-side of the connection would only have one junction instead of N amount of junctions.
Layout wise it is already achievable. It does however require many clicks as well as playing with alignment and placing tunnel junctions on top of each other. Therefore it is easy to snap connections by mistake.
_fabian_
Forum|alt.badge.img+5
  • March 17, 2026
FYI, you can just drag and drop the tunnel line connected to the junction to another junction. So you can already achieve 1:N tunnel connections, but it’s tedious work do reconnect all the lines.
JennaKAtSafe
Forum|alt.badge.img+9
Hi ​@sweco-senari,
I will echo _fabian_’s response and confirm that you can already achieve 1:N tunnel connections.Using junctions from the start may help simplify the process, but I recognize that it can still be time-consuming.
We’ll keep this idea open to see if other users would also find value in this enhancement.
JennaKAtSafe
Updated idea statusNew→Open
