Released
Trimble Connect
Related products:FME Form
  • Oct 29, 2015 12:00 AM UTC
  • 66 views
fmelizard
Forum|alt.badge.img+22
Not so much a format as a source/destination for data files. Idea is that FME would retrieve or push data in / out.
This would be a fantastic capability. Here is a link to the Trimble Connected Community page if anyone from SAFE reads this: https://www.myconnectedsite.com/
Yes please :) Their API is quite powerful and we're starting to build custom applications around it. Unfortunately the authorization process is a bit of a pain as it requires two levels of authentication and then you have to keep passing an access token with each request. Any way to make this simpler would be great (and in Trimble's interest as well if they want to expand usage). PS: You cannot use the web services in FME to authenticate; you have to submit two levels of authentication via an HTTP caller. Their current API documentation (https://app.connect.trimble.com/tc/static/apidoc.html) might also not be correct so if you're trying this out yourself, you might want to get in touch with Trimble support.
warrendev
Forum|alt.badge.img+28
  • Oct 13, 2020 11:42 PM UTC
I would love to have this reader/writer functionality added!
