This applies to anywhere where composite tests can be applied. Currently if you edit the composite expression and do not click apply, the changes are lost when you press OK to close the transformer. I need a warning when there are unapplied changes in the composite expression editor to stop me doing this! Perhaps the OK button could be greyed out if the composite editor is open with unapplied changes?
