Archived
Systemcaller option to hide details from log
Related products:FME Form
  • February 10, 2025
  • 101 views
tva
Forum|alt.badge.img+13
Based upon the question that I had:Β
I still like to work more with FME transformers then using python callers to do same things.
The systemcaller currently shows the command that it executes in the log file. It should be possible with an option to not show this command (like echo off or something like that) as the command can show passwords in plain text.
alexbiz
Forum|alt.badge.img+35
  • February 27, 2025
As an alternative for now, I would suggest using thisΒ :
https://hub.safe.com/publishers/abizien/transformers/bettersystemcaller
JennaKAtSafe
Forum|alt.badge.img+9
Thanks for the suggestion! We’re closing this post for now, as it’s not something we’re planning to pursue in the near term β€” but your feedback is still valuable and helps inform future discussions.
JennaKAtSafe
New→Archived
