Archived
surface modeller / rasterDEMgenerator - allow attributes to populate output dem
Related products:FME Form
  • October 18, 2019
  • 109 views
***Note from Migration:***
Original Title was: surface modeller / rasterDEMgenerator - allow attributes to populate output dem x/y cell spacing parameter
it would be extremely helpful in my workflow if i could use an attribute value to populate the output dem xy cell spacing parameter, i'm using python to extract this information out of the raster@ a specific byte, so i've got them as attributes. Right now it only accepts a parameter or a number.
jdh
Forum|alt.badge.img+41
  • October 18, 2019
It's a little bit complicated to set up, but you could use the PythonCaller with fmeobjects.FMEFactoryPipeline where the factory definition uses attribute values.
LizAtSafe
Forum|alt.badge.img+25
Updated idea statusGathering Interest→Archived
Idea merged into:
All the votes from this idea have been transferred.
