Archived
Support Insertion Scale Units for Autocad_OD
  • Feb 1, 2019 12:00 AM UTC
  • 0 replies
  • 42 views
fmelizard
Forum|alt.badge.img+22
As an FME user, I would like to see support added for insertion scale units on the Autodesk AutoCAD Map 3D Object Data writer so I can specify the units. Currently, the workaround is to use a blank template and specify the units but this is a tedious task that needs to be done each time I want to write a new dataset.
It would be great if there was a parameter similar to the one mentioned in this thread: https://knowledge.safe.com/questions/1906/write-dwg-with-coordinate-system-and-units.html
