FME is currently unable to read Civil3D surfaces directly from the Civil3D dwg file. I have posted my workaround HERE but it is not perfect and requires too much pre-processing before you can read in FME. Also, you would have to remember to repeat those steps every time the source surface changes. I've also experimented with a workspace to derive the boundaries from the LandXML file, instead of one extracted in Civil3D, then trim the surface to those boundaries. But it only works if a boundary was input in Civil3D, still not perfect and still requires a LandXML file be created after every surface change.
Archived
Support for reading Civil3D Surfaces
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
