Open
Support for Pre- and Post-Write SQL Scripts in GeoPackage Writer
Related products:Integrations
  • March 9, 2026
  • 46 views
radioactivetoy
Forum|alt.badge.img+5
I am looking for a way to write to a self-created GeoPackage that contains multiple foreign keys and check constraints. To ensure the data loads correctly without ordering conflicts, I need to temporarily disable foreign key validation by executing:
PRAGMA foreign_keys = OFF;
Once all feature classes are written, I need to re-enable the checks.
Currently, the GeoPackage writer lacks the option to execute SQL scripts before or after the translation process. Using a separate SQLExecutor is not a viable workaround because it operates in a different session; therefore, the pragma command does not affect the writer's connection.
Interestingly, I can achieve the desired behavior using a SpatiaLite writer with a SQL statement on the same file, but this method fails to handle geometry correctly. Due to these limitations, I am considering switching from GeoPackage to SpatiaLite as a temporary measure, though this is not my preferred solution.
Could you please add SQL before and SQL after parameters to the GeoPackage writer to support these types of database operations?
andreaatsafe
Forum|alt.badge.img+17
New→Open
