Archived
Support for IFC 4.3
Related products:Integrations
  • July 1, 2020
  • 5 replies
  • 324 views
sigtill
Forum|alt.badge.img+25
The RC of IFC 4.3 is available at:
https://technical.buildingsmart.org/standards/ifc/ifc-schema-specifications/
Would be great to try out the RC already if possible with read and write with FME. Not sure how IFC is implemented vs XML. However with XML you can fairly easy point to an xsd and get a new xml standard within FME. I guess its not as easy to do the same for IFC + XSD ?
Mostly using this towards roads, railway and bridges
Changes here: https://technical.buildingsmart.org/standards/ifc/ifc-schema-specifications/ifc-release-notes/
What is the status of implementing IFC 4x3? We are starting to get IFC 4.3 deliveries in infrastructure projects, and it would be a value for us not haveing to use other programs to read the files.
pti001
  • November 16, 2023
Leider unterstützt FME ifc4x3 nur sehr schlecht. Obwohl das Format angeblich gelesen wird, können die Inhalte nicht verarbeitet werden. Wir sind sehr enttäuscht von FME (Safe.com)
thomasmarti
Forum|alt.badge.img+9
  • June 24, 2024
IFC 4.3 is now an official release since 04/2024
Is there a roadmap for the integration of IFC 4.3 in FME? We got some projects in pipeline we would like to realise in 4.3
thomasmarti
  • August 14, 2024
Hello developpers and moderators at #safe
Can we get an update to the IFC support? What are your plans?
Thanks in advance
@deanatsafe @daveatsafe
LizAtSafe
  • August 19, 2024
Updated idea statusOpen→Archived
Idea merged into:
All the votes from this idea have been transferred.
