Released
Support for element view independent attribute in DGN V7
Related products:FME Form
  • May 31, 2018 12:00 AM UTC
  • 53 views
lazarlubomir
Forum|alt.badge.img+11
Hello,
I often work with DGN files, especially version V7, and many times I need to map, if element is view dependent or not... As I mentioned below, value for this attribute is filled only in version V8. How complicated is to add support of this attribute in version V7, please?
Thank You so much!
Lubo
andreaatsafe
Forum|alt.badge.img+17
Hi @lazarlubomir,
I'm pleased to let you know that we have now added an attribute igds_element_view_independent for the Microstation DGN V7 (IGDS) format.
You will find this update in the latest FME 2019.0 beta.
lazarlubomir
  • Jan 24, 2019 8:36 AM UTC
Hello @AndreaAtSafe, thank you so much! Its great message, I will test this new functionality! Thank You and developer team so much once again!
Lubo
