Released
Support for Autodesk BIM 360 Docs
Related products:FME Form
  • Jul 24, 2017 12:00 AM UTC
  • 16 replies
  • 103 views
erik_jan
Forum|alt.badge.img+26
FME has an AutodeskA360Connector transformer.
For BIM models Autodesk created BIM 360 Docs, similar to A360.
For more information: https://www.autodesk.com/products/bim-360-docs/overview
For a customer I request a AutodeskBIM360Connector transformer that allows conneting to BIM 360 Docs for uploading and downloading files.
fmelizard
Forum|alt.badge.img+22
  • Jul 25, 2017 5:59 AM UTC
We are under the belief that it will work for BIM 360 docs as well. Perhaps try and let us know? We can add an alias if need be.
  • Sep 27, 2017 2:22 PM UTC
The AutodeskA360Connector only access the BIM360 Team platform. In order to interact with Docs, you might want to have a look into Autodesk Forge where you can create your own apps and connect to a few of their WEB based products (Docs, Glue, Field, etc.) It is likely that Team will be merge into Docs eventually because they're virtually similar.
keithhastings
Forum|alt.badge.img+14
Dale, is there any update on whether we can read & write into BIM 360 docs? Does the AutodeskA360Connector work for this?
atle_hoidalen
Forum|alt.badge.img+3
@daleatsafe are there any plans of developing a BIM360 Docs connector? This would be very usefull.
jasperwis
Forum|alt.badge.img+19
  • Dec 16, 2019 1:27 PM UTC
Is this working successfully for someone?
I can connect to BIM 360, but no object IDs to show.
gabriel_hirsch
Forum|alt.badge.img+15
It doesn't work. To connect to BIM 360 Docs you need to go through the Forge API and create a web connection to it.
davidrasner5
Forum|alt.badge.img+4
  • Dec 17, 2019 1:08 PM UTC
+1, having a DOC 360 connector would be really cool. I use the Data Management API to grab files, or generate reports for our project managers. It works pretty well, but the Forge API is not exactly user friendly, or well documented. :(
Just having a small docs explorer that does the OAuth and returns the proper ids for Hub/Project/Folder/Items would be very useful.
jennaatsafe
Forum|alt.badge.img+5
Hello! Safe is looking for some additional information around this Idea. We've put together a <5 minute survey to help answer some questions. If you've got a coffee break's worth of time to spare, and are a BIM 360 Docs user, we'd really appreciate the feedback. Cheers! Survey will close Monday, July 13, 13:00 PST.
https://forms.gle/Zsxc8yibyQcUvwwT9
@erik_jan @atle_hoidalen @davidrasner5 @keithhastings @sebasdub @jasperwis
I confirm that this issue is still ongoing. A360 is the equivalent of BIM Teams which used to be the hub for C4R (Collaboration For Revit) from Autodesk. On the Autodesk side, BIM360 is a different product within a specific ecosystem (BIM360 DOCS, BIM360 Design, etc.). It would be very usefull to be able to access BIM360 Docs directly.
jennaatsafe
LAST CALL! We've had some great responses so far (thank you for your contributions!), but are still looking for a few more opinions. The survey (linked here) will stay open until end of day Wednesday, July 29 for any last minute responses. Feel free to share with your teams or anyone you think would be a good match. Cheers.
karinabradley
Has there been any further progress made on this connection?
jennaatsafe
Hi @Karinabradley - we have this connector In Development right now. It will be released on FME Hub in the coming months, and we will update this idea when it is live - so look out for that!
jennaatsafe
Safe Software is pleased to announce that we have released the Autodesk BIM360 Docs package to FME Hub: https://hub.safe.com/publishers/safe/packages/autodesk-bim360docs#readme
If you do download and use this package, we would appreciate you taking the time to give us your opinion on it by filling out this feedback survey: https://forms.gle/m9X6nMm5soGLjXcq8
Thanks for being a contributor to our Community, and a user of FME!
jennaatsafe
An update from Safe Software:
  1. The official feedback survey for this package is still live. If you are trying out this package, we'd appreciate you taking a few minutes to let us know how we are doing: https://forms.gle/m9X6nMm5soGLjXcq8
  2. We have launched a new article to explain the process to create the web connection. You can find that here: https://community.safe.com/s/article/How-to-create-a-BIM-360-Document-Management-Web-Connection
matthew_b1985
Great Transformer - I'm starting to use it, although it was rather fiddly to set up the BIM360 side of things.
I have a question on functionality:
On 'List' mode I am able to expose certain Output attributes - i.e. Created, Created_by, _full_path, _version etc etc.
But not expose all of the attributes that are in the BIM360 folder.
Is it possible to expose other BIM360 Document Management Attributes from a folder - for instance any other attributes such as 'Description', Approval Status that have been added within BIM360?
jennaatsafe
Hey @matthew_banyard! Thanks for reaching out to us here with feedback - it's always great to get opinions from out in the field.
We currently do not support the attributes that you are mentioning here, but we could look into it if we had more information. If you could pull together a list of the specific attributes that you need, and Submit a Case https://community.safe.com/s/submit-case/ with the information, that would help us to understand what you are looking for.
I (obviously) monitor this forum as well, so for anyone reading this - if you post specific details of your triumphs and trials you've had working with this Connector - we'll take that into account for future development.
Thanks all!
