Open
Support for 12dxmlz file format
Related products:Integrations
  • Oct 20, 2022 7:19 AM UTC
  • 110 views
ltwigg
Forum|alt.badge.img+3
Currently FME can read 12dxml file format (.12dxml), but cannot directly read the zipped version of this file (.12dxmlz).
This is similar to the difference between a Google Earth KML file and a KMZ file.
A current work around is the routine can have a user parameter for file name, it starts with a creator, uses the "ZipExtractorAnyExtension" from FME hub to extract the file, then the file path can be used in a feature reader with the format set to 12dxml.
There are two issues with the workaround - it requires a user parameter to be setup within the routine, and it requires unzipping the file contents to a folder prior to being usable in the routine. 12dxml files can be large compared to 12dxmlz (7mb vs 206kb) so file size is significant, especially when 12dxmlz files get into 100mb's+.
That is why a dedicated 12dxmlz reader would be great.
ctredinnick
Forum|alt.badge.img+22
  • Oct 24, 2022 10:41 PM UTC
First of all, it sounds like .12dxmlz just needs to be recognised as a zipped format of .12dxml, in the same way that FME recognises it can read kmz with the kml reader.
A different workaround is to rename the file to .zip, and try read it with the 12dxml reader. You may have to specify the whole filepath to read it (point the reader at C:\\Temp\\thefile.zip\\thefile.12dxml, not C:\\Temp\\thefile.zip) . Either way, that'll prompt FME to unzip it itself. You can do that without creating extra data to cleanup by using a TempPathnameCreator, and a FileCopy FeatureWriter to create a renamed copy of file into a temp directory.
ltwigg
  • Oct 25, 2022 11:06 PM UTC
Great idea, thanks for this.
I will also try testing to see if that extended path concept can work if it's left as 12dxmlz (since the 12dxml file will have the same file name).
