Open
Support DataDownload, DataStreaming & DataUpload in the FME Server REST API
Related products:FME Flow
  • October 10, 2017
  • 6 replies
  • 155 views
fmelizard
Forum|alt.badge.img+22
Currently, the DataDownload, DataStreaming & DataUpload services have their own API:
DataDownload Documentation
DataStreaming Documentation
DataUpload Documentation
The JobSubmitter service is already supported via the FME Server REST API and can be invoked with a set of REST Calls:
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/#!/transformations
I would be nice if all 3 services (DataDownload, DataStreaming, DataUpload & JobSubmitter) could be invoked via the FME Server REST API to make it easier for developers to leverage the power of FME Server. This would allow for more consistent application development without worrying about different APIs for one product.
tino
Forum|alt.badge.img+28
  • November 22, 2017
Please integrate also the FMEToken Service to the endpoint <HOSTNAME>/fmerest.
It would really help in ReverseProxy architectures to have only to forward one endpoint (two with the UI) to the FME Server machine.
This would also bring consistency in the authorization format between the REST API and the other services. For example in data streaming you cannot use a token in the Authorization header.
  • December 6, 2018
Yes you can. You can call your Data streaming workspace with direct URL and use the fmetoken as Authorization header.
Yes please, this would be great to have....we just ran into this limitation and are having to change the way we make FME Server calls via our separate custom application.
We just hit this too. A consistent way to interact with the different methods would be great! The nicely formatted json payloads are so much easier to work with than URL params.
chriswilson
Forum|alt.badge.img+29
Would be a useful addition to the REST API
