Currently the ESRI Reprojector does not support composite transformations like ArcMap does. It would be great to see FME could adopt this functionality. A common reprojection from NAD27 to WGS84 typically requires a composite transformation and the way to do this with FME at present (FME 2017.1) is to use two ESRIReprojectors. For those used to the ESRI workflows this can be a big trip up.
