New
Suggest schedules when creating Flow Hosted Instances
Related products:FME Flow Hosted
  • March 27, 2026
  • 30 views
gabrield
Forum|alt.badge.img+15
Since it does not seem possible to automatically shutdown an instance in FME Flow Hosted, one workaround we found is to apply schedules to shutdown the instances. However, this is done manually and can be easily forgotten. A good way to ensure the instance has one is to suggest a schedule at the creation, with having a certain default value created.
Hope this makes sense, let me know if this sparks any more ideas or if you need further information on the subject!
d_l
  • April 1, 2026
While I agree it could be useful to have a schedule creation suggestion when creating the instance, I recommend you have a look at the FME Flow REST API to programmatically start, stop, reboot and terminate your instances: https://api.fmecloud.safe.com/api/documentation/#/
