Open
Style FME Flow
Related products:FME Flow
hkingsbury
Forum|alt.badge.img+73
Lots of organisations have several FME Flow Instances, Dev, Test, Prod for example.
It would be helpful to have the ability to select different colour pallets for each environment to quickly differentiate between each env.
For example, you would be able to change the sidebar colour to blue for dev, green for test and red for prod
hkingsbury
​@NickAtSafe ​@rylanatsafe
Forum|alt.badge.img+63
Great idea! I'm all for it!
j.botterill
Forum|alt.badge.img+69
​@todd_davis suggestion on interim solution of a “broadcast message” is also neat idea.
Maybe the deployment parameter could be included to help define the colour of the UI when connecting to a database? just an idea
database connection - deployment colour and style setting
Otherwise I think the Flow GUI colour could be set where the user can change the dark/light mode
dark vs light mode consideration
nathanatsafe
Forum|alt.badge.img+9
New→Open
philippeb
Forum|alt.badge.img+23
I would love a DOS mode!!
matthieuv
Forum|alt.badge.img+30
A broadcast message is only visible on the dashboard page and not on all pages in FME Flow. If that changes it could be used to tell the user which environment is open.
nathanatsafe
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
