Released
StatisticsCalculator interface update
Related products:FME Form
  • Mar 11, 2019 12:00 AM UTC
  • 85 views
davideagle
Forum|alt.badge.img+21
The StatisticsCalculator has received a much needed interface update in FME 2019 to limit the volume of automatically generated stats that are tagged onto outgoing features, but I'd like to see even more done here. 90% of the time you actually only need to calculate 1 statistic so I'd much rather see the transformer adapted to operate more like the GeometryFilter where you chose which stats you wish to generate and add them on. This has the impact of people not over generating stats and then having to delete them later, plus it'll be quicker because users don't call more functions than is necessary.
This change is focused on efficiency because in training, delegates rarely realise immediately that statistics in here are 'optional' to generate and when they do they spend time fiddling trying to remove them.
Forum|alt.badge.img+54
  • Mar 11, 2019 12:24 PM UTC
I think there's room for improvement for sure. I have my default statistics calculator so that only count is populated, which saves having to delete a lot of the time but does mean more typing if you do want additional statistics. Default of nothing populated would be great with an option to auto generate the attribute names (but still enabling editing after) for selected statistics
davideagle
  • Mar 15, 2019 11:02 AM UTC
Good idea.
  • Mar 15, 2019 11:26 AM UTC
I think maybe the new facility to allow multiple defaults/'presets' announced for 2019 will be able to handle this quite nicely - of course would require some setting up. I've not looked yet, so don't know how easily it would be to share defaults between users.
mark2atsafe
Forum|alt.badge.img+59
Does the update for 2020 solve the issues here? The only drawback (to me) is the lack of renaming capability, though of course there are many other transformers to handle that.
