Archived
SQL Transformer - read SQL from file
Related products:Transformers
  • Oct 11, 2016 12:00 AM UTC
  • 44 views
davideagle
Forum|alt.badge.img+21
The SQL transformers allow you to hardcode your SQL in the interface or select it from an attribute constructed earlier in the process. It would also be nice to be able to run SQL "from file" where the code is stored externally in a *.sql file. This could be a little like the flexibility offered in the FTPCaller "upload from a file" or "upload from an attribute".
verdoodtdries
Forum|alt.badge.img+23
Hi 1spatialdave,
I've made my own custom transformer and published this on the FME HUB. It is called SQLStatementFilter.
It basically accepts an .sql-file and omits blank spaces, omits comments and concatenates all lines to return one sql-statement.
This statement can than be used inside an SQLExecutor transformer.
