Released
Speed up data retrieval from running workspace run with full inspection
Related products:FME Form
  • November 18, 2016
  • 42 views
lifalin2016
Forum|alt.badge.img+41
Running a workspace with full inspection is a great tool, but it comes with a heavy price.
If - which is often the case - a huge dataset is among the inputs, the "inspection cache" is swamped with unnecessary data. This makes inspection of even minute datasets generated later in the workflow a tedious and slow task.
Would it not be possible to somehow index the cached inspection datasets, so retrieval becomes as fast as the individual dataset size determines, i.e. very fast for small amounts ?
The performance is currently just as bad in the 2017 beta as in 2016 release.
Cheers
Lars I.
fmelizard
Forum|alt.badge.img+22
Good suggestion. We'll look at how we might partition things better.
fmelizard
We've got a plan and it is tracked in PR 72445 (in case this comes up again)
mark2atsafe
Forum|alt.badge.img+59
Fixed in 2017.1 (the DI will not be slow to inspect one piece of data if the dataset is very large)
