Open
SpatialFilter: output per predicate
Related products:Transformers
danilo_fme
liamfez
p_c_20
  • danilo_fme
    danilo_fme
  • liamfez
    liamfez
  • p_c_20
    p_c_20
p_c_20
Would like to see the ability to have multiple output ports - one per predicate.
s.jager
Forum|alt.badge.img+16
  • February 19, 2025
How would you propose to deal with a single feature, that receives multiple predicates?
Send them through every appropriate port, thus creating duplicates? Or only through the first matching port?
p_c_20
Forum|alt.badge.img+8
  • February 19, 2025
I’d say the former. But you could have the latter as an option.
liamfez
Forum|alt.badge.img+34
  • February 19, 2025
I could see this working like the TestFilter. So you would order the tests in the order that you want, assigning the tests to different or same ports.
p_c_20
  • February 19, 2025
A SpatialTestFilter
liamfez
  • February 19, 2025
p_c_20 wrote:
A SpatialTestFilter
Yeah, perhaps this would be a new transformer? Renaming the current SpatialFilter to SpatialTester?
p_c_20
  • February 19, 2025
liamfez wrote:
p_c_20 wrote:
A SpatialTestFilter
I expect a Zipster t-shirt for this.
andreaatsafe
Forum|alt.badge.img+12
Thanks ​@p_c_20 for the idea!
I’m curious if using the AttributeFilter on the output attribute for the predicate would work for you? If this doesn’t work for you, could you explain a little bit more about why you’re wanting one port per predicate.
I see from the follow-up comments though that maybe the real issue is wanting to have control of the order the Spatial Predicate Test?
andreaatsafe
NewOpen
danilo_fme
Forum|alt.badge.img+44
  • April 22, 2025
andreaatsafe wrote:
NewOpen
Thanks ​@andreaatsafe for update it!
p_c_20
  • April 23, 2025
Hi, ​@andreaatsafe ! With the caveat that I haven’t had coffee yet…..
What I like is flexibility. Different tasks throw up different use cases - and of course, it’s not just for me (how selfish would that be?); these things have to work for the largest possible number of members of a massive community.
So, with that in mind - yes, I think control over the order would be a good thing.
I do, however, wonder if there is still a case for saying, ‘which of these predicates do these features satisfy?’
Similar to ‘pass against one/pass against all’ you could have setting which enables ‘output all successes’, giving one port per predicate outcome.
Admittedly, I don’t believe I have plumbed the full depths of SpatialFilter, so maybe I can hack this together using existing functionality somehow.
