Released
Sorter options for handling null, missing, empty string, non-numeric
Related products:Transformers
  • Mar 21, 2017 12:00 AM UTC
  • 11 replies
  • 317 views
tim_wood
Forum|alt.badge.img+8
Picking up on questions such as
https://knowledge.safe.com/questions/4786/null-sorter.html
and comparing the FME Sorter to Excel, which sorts empty cells to the bottom (for a numeric sort)...
I'd like to suggest adding options to the Sorter or creating a "PedanticSorter" transformer with options allowing the user to sort certain types of values to the end, including nulls, empty strings, non-numeric etc. There could be a drop down box with "sort to end" and "sort to beginning" for each value type. For non-numeric this would apply when you choose to sort numerically but some of the values are not numeric.
A further option could be a "rejected" output port. Then the drop down list for each value type would include "Output via rejected port" as a third option.
tim_wood
  • Mar 21, 2017 3:27 PM UTC
"Sort to top" and "sort to bottom" would be better wording for the choices + "output via rejected port".
The default option for each value type would be whatever Sorter does now (usually sort to top), thus maintaining backwards compatibility if the transformer was upgraded old Workspaces.
tim_wood
  • Mar 23, 2017 11:27 AM UTC
So the next question is how do we sort these attribute types among themselves if two or more if them exist in the data? For example the attribute includes null AND empty string values.
I would say null comes before empty string if sorting to the top but what about when sorted to the bottom?
Is a hard coded rule acceptable or does it need to be user configurable?
mark2atsafe
Forum|alt.badge.img+59
Hopefully this hub transformer does what you need:
https://hub.safe.com/transformers/controllednullsorter
tim_wood
  • May 1, 2018 1:01 PM UTC
Thanks @Mark2AtSafe. I haven't had chance to try this yet but as soon as I do I'll feed back :-)
erooen
  • Aug 5, 2021 2:17 PM UTC
Another option I have used as a work around uses a combination of NullAttributerMapper-->Sorter-->NullAttributerMapper.
Begin with the first NullValueMapper by mapping your NULL, Missing or Empty value to a value you know will be at the top or bottom of your sort (i.e. ZZZZ for a an alphabetic ascending sort). This will replace the value to be used for the Sorter. After your sort load a new NullAttributeMapper and set all of your ZZZZ back to NULL, Missing or Empty. The sorting will remain unchanged after this final mapping.
A bit clunky but it works!
mark2atsafe
Now called the AdvancedSorter I believe.
gmbutler2
Forum|alt.badge.img+10
  • Dec 28, 2023 2:09 PM UTC
I actually like the way you think! What I did was simple. I used a tester to look for null, missing, or empty based on specific value that was causing problems. I then create an attribute called sort priority, if it is null I set priority to 1, if it is not null I set priority to 0. Then I apply that to the sorter before sorting that specific value. Thanks for pointing me in a solid direction!
LizAtSafe
Forum|alt.badge.img+26
  • Feb 11, 2025 9:35 PM UTC
Open→Gathering Interest
LizAtSafe
  • Feb 21, 2025 8:15 PM UTC
LizAtSafe
  • Jul 8, 2025 12:03 AM UTC
Gathering Interest→Released
andreaatsafe
Forum|alt.badge.img+17
This has now been released in FME 2025.1!
There is now a new option called “Sorting Exceptions”. This will control where values outside of the scope of the sorting method (eg. non-numeric values when the Method is Numeric and missing, null, or empty strings) will sort to either before or after the successfully sorted features.
