Released
Sorter may have Group By and Parallel Processing Level Parameters
Related products:FME Form
  • November 25, 2015
  • 5 replies
  • 95 views
When the user needs to sort huge number of features grouping by an attribute value, it could be performed more efficiently if the Sorter had the Group By and Parallel Processing Level parameters. In the expected Sorter, when the user has set an attribute to the Group By parameter but not set sort keys, it should work to just make the order of features by group. If it could be done efficiently in conjunction with parallel processing, the performance of a following transformer that has the "Input is Ordered by Group" parameter could also be improved. e.g. Aggregator.
mark2atsafe
Forum|alt.badge.img+59
Already filed in our system as PR#19404. I've increased the priority and posted a link to this page so we are notified if and when it is completed. Note that you can do this now by adding the Sorter into a custom transformer. You can give the transformer a group-by and use parallel processing.
  • November 27, 2015
Thanks for your comment. I know the tip, but Workbench sometimes crashes when running a workspace containing a custom transformer that publishes parallel processing parameters. In my observation, the condition to crash is - Parallel Process By: <an attribute>, Parallel Processing Level: No Parallelism. Try with Workbench 2015.1.3.
I suspect that there is an issue on memory leak, and have reported a related issue to your support team before - C96706 (PR#56018). Fixed in 2016?
sorter-groupby-parallelprocessing-b15573.fmw
mark2atsafe
Yes, PR#56018 is reported fixed.
  • November 28, 2015
Good news, thanks!
chriswilson
Forum|alt.badge.img+29
I would like to see this. It would be great, though I don't know how easy, if the sorter could sort and release some features batch by batch rather than blocking everything all at once. I have some huge processes to run and would be interested to see how best to do this - fairly new to big data!
