Open
Skip automation trigger if it is already running
Related products:FME Flow
becchr
Forum|alt.badge.img+35
In automations, for the action “Run a workspace”, there’s a ‘Skip if Job In Progress’ option, I think a ‘Skip if Automation In Progress’ on the level of the automation itself would be very useful!
The purpose of this option would be to prevent the same automation from being initiated again if a workspace from that automation is currently still running or queued. This could help prevent unnecessary duplication of processes and especially potential conflicts.
We have some complex automations we really want to avoid to be run in parallel, but at this moment we don’t have an easy or nice solution for that...
nordpil
Forum|alt.badge.img+12
  • April 22, 2024
I have implemented this in the past with a simple workspace to check currently running and queued jobs (using REST API) - and put that workspace as an action right after the automation trigger. In my case we’d wait for all other jobs to finish (so my ‘wait/check’ workspace would hog an engine) and then proceed. One can also consider just terminating if it is already processing.
like the first comment on this topic:
LizAtSafe
Forum|alt.badge.img+25
New→Open
LizAtSafe
This is related to https://community.safe.com/ideas/disable-same-workbench-ability-to-run-simultaneously-31793
nic_ran
Forum|alt.badge.img+20
  • July 15, 2025
I would like to add a request for similar functionality (since it looks like ​@LizAtSafe has already grouped a couple of similar Ideas).
  • This should also apply to Automation Apps, to prevent a user manually triggering an Automation multiple times
  • This should also apply to Workspace Apps to prevent a user running a workspace multiple times
