Open
Single-View Attribute Transformer
Related products:Transformers
  • Jun 17, 2024 12:51 PM UTC
  • 78 views
danii
Forum|alt.badge.img+33
It would be beneficial to have a transformer that displays all attribute values simultaneously, rather than using the TestFilter Transformer. In some cases, I need to process each value, which can be time-consuming when using TestFilter to have each attribute value on its own tab.
Forum|alt.badge.img+63
Have you tried the AttributeFilter transformer? If you import the unique values from the source dataset or the feature cache it saves you a lot of work.
danii
  • Jun 17, 2024 2:48 PM UTC
@redgeographicsΒ Thanks for the tips! However, I still believe it would be beneficial to have an own transformer to display attribute values without the need to import them. Just connect the transformer, and voilΓ , the attributes appear.Β πŸ˜‰πŸ˜‰
LizAtSafe
Forum|alt.badge.img+26
  • Sep 23, 2024 9:45 PM UTC
New→Open
