Released
Single Sign on for Portal for ArcGIS
Related products:FME Form
  • August 17, 2017
  • 8 replies
  • 83 views
salvaleonrp
Forum|alt.badge.img+23
Since 2016, "all HTTP-based formats received a new SSO authentication option". At about the same time this announcement was made, Portal reader and writer were also released but the reader has issues depending on your authentication options; the writer is also somewhat broken as it works with writing new feature layers only but not updating existing feature layers. I wonder if the update would work if SSO is added.
salvaleonrp
  • January 9, 2019
With ESRI adding OAuth2 support for ArcGIS Enterprise (Portal) and ESRI's Utility Network getting more traction this year and the next few years adding SSO, including OAuth2 - would get more users to use this reader/writer.
runneals
Forum|alt.badge.img+32
  • January 22, 2019
I noticed this the other day in the HTTP caller (when I was hitting a query URL that returned json for a feature service). Could SSO be included for ArcGIS Server Features, and maybe even ArcGIS Online readers/writers? Would be SOOOO nice!
mmccart
Forum|alt.badge.img+33
  • January 31, 2019
It would be nice to have SAML support for ArcGIS Enterprise and ArcGIS Online readers/writers. We're seeing more and more larger agencies leveraging Azure and Okta as a SSO solution.
ngoorman
  • June 12, 2019
Hi, have there been any updates on this? SSO would be great as currently we'd need to create fixed accounts in Portal to allow people to use FME to update data.
runneals
  • June 14, 2019
Chatted with SAFE a couple of months ago on this, and it sounds like they're working on adding the same functionality that ArcGIS Online has (OAUTH) in a future version.
gtiemens
  • September 16, 2019
Datamanagement of a Enterprise Portal using Oauth2, using FME Server will be important for us. So adding new featureservices, and update existing ones.
meijer
  • September 18, 2019
Now we need to add a hard coded user/password into the workspace. We would like to work with webconnections. The reader 'Esri ArcGIS Server Feature Service' can also be updated
debbiatsafe
Forum|alt.badge.img+24
This idea has been implemented in FME 2020.0 and 2019.2--ArcGIS Portal formats now supports authentication using OAuth2!
Organizations using SAML or federated login should authenticate by setting up an OAuth 2.0 Web Service. For detailed instructions, please see: https://knowledge.safe.com/questions/110816/how-to-create-an-fme-web-connection-for-your-esri.html
Should this feature or its implementation not address your concerns, please let us know by leaving a comment.
