Open
Simplify Input of Search Envelopes
Related products:Transformers
  • Oct 29, 2015 12:00 AM UTC
  • 7 replies
  • 88 views
roland.martin
Forum|alt.badge.img+11
Simplify input of Search Envelopes somehow - it would be nice to only have to deal with one dialog box (actually, ideally one text box even) rather than the current 4-6.
roland.martin
  • Oct 29, 2015 3:51 PM UTC
@dalelutz3 One possible solution might be if the FeatureReader (best transformer ever, by the way) could be combined with the normal readers - i.e. every reader has an optional input connection which allows you to do the spatial intersection / attribute join?
fmelizard
Forum|alt.badge.img+22
@rolypole Literally as you were typing this we were looking at exactly this issue today. Definitely room for improvement here.
fmelizard
@rolypole Very interesting idea. We'll continue to give this thought -- already this has made me think perhaps we need an "AreaOfInterestCreator" which pops up a background map and lets you draw a rectangle -- it then emits a feature with these bounds that can be used as input to FeatureReader Good discussion.
geogeoff
  • Nov 26, 2015 7:31 PM UTC
A graphical AOI Creator would be awesome.... it would allow user to change AOI envelope quickly to verify and test difficult issues.
lifalin2016
Forum|alt.badge.img+42
  • Sep 19, 2016 8:05 AM UTC
Maybe also add a checkbox, that enables/disables the search envelope function without removing the values ?
esko
  • Jun 12, 2017 11:00 PM UTC
Why not : (1) enable a leaflet-like pop-up window with user's choice of background map (eg. pre-configured into Data Inspector) (2) let the user draw a bounding box with his/her mouse and (3) import corner coordinates back to the search envelope dialog.
Helps enormously when testing with huge datasets and you know an area where you can pick a representative sample.
kuanglee
Agreed. Alternatively, if a reader can browse to a shapefile or Esri featureclass in FGDB, or SDE as a AOI, it would be a PLUS.
