Archived
Significantly improve "Rejected" error message information from FeatureReader
Related products:Transformers
  • November 24, 2016
  • 48 views
lifalin2016
Forum|alt.badge.img+41
I’m trying to build a dataflow using FeatureReader to read my files.
Whenever I encounter a file with an error, the log file contains this snippet:
2016-11-24 09:50:12| 994.1| 0.0|INFORM|Expected a value string for '%L1KR', found '%KM1' instead, in line '916' of input file
2016-11-24 09:50:12| 994.1| 0.0|INFORM|DSFL halted, approx. line in input file: '916'
2016-11-24 09:50:12| 994.1| 0.0|ERROR |Error DSFL expected a value string from the input file
2016-11-24 09:50:12| 994.1| 0.0|INFORM|Closing the DSFL reader
However, the feature output by the “<Rejected>” port of the FeatureReader only contains a single “_reader_error” attribute with very limited content:
Would it be possible to enhance this error output significantly, preferably adding more error information (e.g. the offending line number), but at least so that the error message attribute reflects the full error messages shown at the top in the log file ?
Cheers
Lars I.
lifalin2016
  • January 28, 2019
To add to my previous suggestion, how about adding the transformer name and other relevant attributes pertinent to the reader format in the REJECTED port as well ? As it is now, it's anyones guess which transformer failed if multiple FeatureReader rejected ports end up in the same error handling.
