Archived
Show which updates were made in the xmlupdater transformer
Related products:Transformers
jakethepainter
Forum|alt.badge.img+7
When using the xmlupdater, there's not a good way to see which of your updates actually worked. You always get xml out, but it's not immediately obvious how it has been changed. It would be nice if there were a way to have an output of each update that was performed on the xml, or a way of seeing which features that you send in successfully altered the xml or not. Or just an output per feature that has attributes that show the results of the parameters for that feature.
