Archived
Show Reader and or Writers that has been upgraded - Same as transformers
Related products:Integrations
  • June 1, 2016
  • 43 views
rudy_v
It would be great to show which readers or writers has change from previous versions. I just had a classic example of why it is needed.
I have migrated a 2014 workbench to 2016. i tried running it and it failed on startup, with import arcpy, could not find arcgis. The user have no idea that the reader format as changed (in the case the Geodatabase reader has change significantly)
After add the new reader format - it seems to work
same applied to the geodatabase writer
  • June 1, 2016
Could it be that the custom Python interpreter that includes arcpy wasn't set in the installation of FME 2016?
rudy_v
  • June 8, 2016
It tried, i don't think it works quite well, all the other extensions work, all but arcpy. I think FME should install in the default python / user choice installation. With this you can have everything in one place. Or user can choose to use FME own python
