New
Show counts inside transfomer output ports
Related products:FME Form
  • May 28, 2025
  • 0 replies
  • 22 views
mperry
Forum|alt.badge.img+9
Hi there, when using hidden connections, I still like to know the counts of features going through the outputs, however using hidden connections doesn’t show this. I can add a junction afterwards to show the count and then create a hidden connection, but it looks a bit messy to do that for things like test filters etc. So putting counts inside the transformers seems like a good idea. Can have the ability to turn this off if needed. Alternatively, can show the count at the start point and end point of a hidden connection
