Archived
Setting to dynamically drop any abandoned attributes during run
Related products:FME Form
Could there be an option/setting/toggle that would analyze workspace at start of run for the optimal place to "kill" or drop any attributes which are not ultimately get written or used to derive some other value beyond a certain point? That way they are still shown as available at every stage in the workspace so that the author has full access to them. This would increase run performance because those attributes don't get (cached/processed) beyond where they are needed while also sparing the author from having to add/configure the attribute keeper transformer, which can cause additional headaches later as the workspace evolves and you suddenly need that attribute you dropped somewhere earlier. Could call it the Dynamic Orphaned Attribute Killer workspace parameter, jk.
