Archived
Set FME Server workspace Log settings
Related products:FME Flow
darkspatiallord
Forum|alt.badge.img+8
Currently you can disable FME job logging if you turn off all your log options in Desktop prior to uploading your workspace to server.
Create a setting in the upload process as a check box to turn logging on or off for that workspace.
IS already case C117368 and PR enhancement request #30438
@daleatsafe @aaronatsafe
denniswilhelm
Forum|alt.badge.img+21
I think it would be even better, if this would be an option in the Workspace Parameters (Navigator)
runneals
Forum|alt.badge.img+32
  • June 6, 2019
Maybe my idea is similar, but I envisioned to set the logging on server as a whole instead of in each individual job (basically how logging is set on ArcGIS Server/Portal).
