Archived
Set Esri File Geodatabase Writer Mode Per Feature Class
Related products:Integrations
  • October 29, 2015
  • 55 views
lars_de_vries
Forum|alt.badge.img+10
Is it possible to change the Esri Filegeodatabase writer in such a way that the Writer Mode (Advanced parameter) can be set per feature class, in stead of the full database?
lars_de_vries
@dalelutz3 Thanks for the tip. I guess I will have to have some patience than, since I always use the ArcObjects version. I'll see in which cases I can go for the API reader instead of ArcObjects. I often use relationships and write multipatches and both of them are not supported in the API.
fmelizard
Forum|alt.badge.img+22
  • October 29, 2015
@larsdevries1 RE: File geodatabase and writer mode -- if you have FME 2015 and you have a newly added File Geodatabase API writer (not the ArcObjects one), then you can do as you wish. We anticipate FME 2017 for ArcObjects based "update mode harmonization".
