Released
Set default logging level on FME Server
Related products:FME Flow
  • Jun 6, 2019 12:00 AM UTC
  • 133 views
runneals
Forum|alt.badge.img+32
Would be really nice to have the option to set the log level at FME server instead of have each job log differently based on what the user's options were set to when they uploaded it. This would help with consistency, and allow those who want debug level logs for each job to keep those.
  • Jun 6, 2019 3:24 PM UTC
Definitely! Or maybe even have it as a workspace setting, e.g. somewhere here
rylanatsafe
Forum|alt.badge.img+14
As of FME Flow 2024.1, you can enable a new 'Log Debug' setting directly under Advanced Parameters when configuring FME workspaces in FME Flow. This feature supports Run Workspace, Transformation Services, Schedules, Streams, and Workspace Apps, simplifying the process of adjusting log levels during execution.
It’s designed to:
  • Streamline troubleshooting.
  • Avoid performance issues from excessive logging.
  • Eliminate the need to adjust settings in workspace or configuration files.
We will be adding support for ‘Log Debug’ in Automations in a future release.
LizAtSafe
Forum|alt.badge.img+26
  • Nov 29, 2024 5:49 PM UTC
In Development→Released
LizAtSafe
