Open
Server Apps: Option to expose 'Email results to' parameter
Related products:FME Flow
  • October 23, 2019
  • 6 replies
  • 185 views
fmelizard
Forum|alt.badge.img+22
On the Run Workspace Page in FME Server there is an optional parameter 'Email results to' which can be used to send out Workspace results if the corresponding Subscription has been configured. When I create a Server App I would like to have this parameter listed as optional to 'Show in App' alongside the workspace published parameters.
g_karssenberg
Forum|alt.badge.img+10
This 'Email results to' box should really be present in the FME Server App interface. This is default functionality when running logged in in the FME Server web application. For apps that run for a long time, not being able to provide an email address is a major downside for using FME Server Apps.
Being able to choose when sharing as an app would be nice, but my main concern is the availability at all. We would like to use the Apps mechanism, but this is a big show stopper.
michaelhaertel
+1
It's not only because a workspace may run longer than a browser usually should wait for a response but also because engines (licenses) are limited.
If there is a long active queue on the server the user of an app can't expect his workspace to run immediately after having been started.
dbaldacchino1
Forum|alt.badge.img+14
Thanks @hollymcoxon for adding this after my support ticket back in October :) This doesn't seem to have been implemented yet in 2020.1 but now that you can force a server app to require login (I don't believe that option existed at the time), once could potentially still use a workspace that automatically emails an attachment to the logged in user. Will now test to verify the above...thanks for adding (just voted as I completely forgot!)
dbaldacchino1
That doesn't work actually because the server app uses a token associated with the user account that created the app in the first place. The "require login" option is to allow that user to run the app, but it still runs as the original user that sets it up, not as the user that authenticates.
itsmatt
Forum|alt.badge.img+48
  • October 26, 2020
Yeah - just came across this issue. Would be great to have this as an optional input. Seems like a pretty easy option to include.
LizAtSafe
Forum|alt.badge.img+25
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
