Archived
Scheduling a repository to run workspaces as a batch.
Related products:FME Flow
  • August 30, 2018
  • 61 views
This might already be an idea mentioned here that I simply have not come across yet. But in a recent chat I was recommended to post this as an idea here to be voted on.
What I suggest is a scheduling method on server which allows all workspaces in a single repository to be ran as a batch set, or in an ordered set by the user. This would be accomplished with a single scheduled time of start at the schedule page on server and choosing the repository alone to run all workspaces within. As far as I know, currently each workspace has to be scheduled individually, regardless if it resides in the same repository.
If there is a method already in place in 2018 server which can perform this I am not aware and would love to learn how to do it.
Thanks,
Todd
  • August 31, 2018
As an alternative, it is easy to create a master workspace that simply chains together several FMEServerJobSubmitters, then schedule the master workspace.
  • August 31, 2018
Thanks @david_r. I had thought that might be an alternative, but thought I'd suggest this for a future build if it's found feasible. As with anything using FME, there's probably a way, or several, to get the task done.
